JLMcNeal
Aug 25, 2026Aspirant
No Internet to WiFi connected Items
Nighthawk BE9300. Is connected to the internet & WiFi transmitting but no internet connection to connected items, I have powered down with no effect. 2.5G hard wired connection has no issue. No ide...
Aug 28, 2026Guru - Experienced User
JLMcNeal wrote:Nighthawk BE9300. Is connected to the internet & WiFi transmitting but no internet connection to connected items,
I have powered down with no effect. 2.5G hard wired connection has no issue. No idea where to go from here.
Is this a new setup?
If it is, then you could try phone support. In addition is the WAN cable connected to to the yellow ethernet socket?
If a client connected to the 2.5G LAN port works ok, then a problem with DNS is ruled out. This needs to be a wifi issue of some kind. What wifi settings (if any) did you change when you did the setup? In partcular, did you set up MAC access controls?
