slawek
Oct 14, 2025Aspirant
ONT Leox Netgear Nighthawk RS700 802.1Q
Hello I need your help to solve the problem of lack of 802.1Q in RS700 which is necessary to replace ISP’s (T-mobile PL) Sagemcom Fast 5670 TMPL. The Sagemcom’s soft lets me change the wifi name ...
slawek
Thank you Furry for quick reply.
The ISP sent me that list twice, so i assume that there are no other settings.
Off/on in sequece doesn't help.
Shall i configure the switch in any special way or just plug in?
- FURRYe38Oct 14, 2025Guru - Experienced User
IF those are non managed switches then there is no configuration needed.
