L3gacy
Jul 11, 2025Aspirant
PNY PRO Elite V3 and Nighthawk RS700 ReadySHARE
I just picked up a PNY 1TB Pro Elite V3 USB stick. I wanted to use it for ReadyShare, but I can not get my $800 Nighthawk RS70 (What I paid at the time) to pick it up? Anyone else having this issue a...
- Jul 11, 2025
It was exFAT after I formatted and make it NTFS it worked. Thank you
Jul 11, 2025Guru - Experienced User
What FW is loaded on the router?
USB drive formatted correctly? I believe NTFS should work:
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Do other drives work?
Is not seen in the routers web UI for Readyshare?
L3gacy
