L3gacy
Jul 11, 2025Aspirant
PNY PRO Elite V3 and Nighthawk RS700 ReadySHARE
I just picked up a PNY 1TB Pro Elite V3 USB stick. I wanted to use it for ReadyShare, but I can not get my $800 Nighthawk RS70 (What I paid at the time) to pick it up? Anyone else having this issue a...
- Jul 11, 2025
It was exFAT after I formatted and make it NTFS it worked. Thank you
L3gacy
Jul 11, 2025Guru - Experienced User
Ok, that format isn't supported. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
