tgeorge
Oct 12, 2025Aspirant
Power connector on Router very loose & disconnects internet frequently
I have a Nighthawk BE18000 WiFi 7 Tri-Band Router (RS600) - I bought it used on Amazon on July 23, 2025. This router was previous registered by a different owner. Looks like this router was released ...
Oct 13, 2025Guru - Experienced User
You'll need to make contact with NG support and have them help you get the unit deregistered and Armor moved over once it's fully registered in your name.
Registration and Un Registering products Help | NETGEAR Communities
Is power connector on 2nd router still loose or working as it should be?
