Caden_Cotard
Feb 13, 2024Aspirant
Preamble Puncturing feature in RS700- Nighthawk Triband WIFI 7 AP
Hi
I have been using this Netgear access point for a while
BE19000 WiFi Router (RS700S) Nighthawk Tri-Band WiFi 7 Router, 19Gbps, 10 Gig Ports with 1-year NETGEAR Armor™. I want to check the preamble puncture mode. I observed that the "Disabled Subchannel Bitmap" is 0 but as per the IEEE BE draft, if puncture is detected the AP will enable the bit. Even after creating interference in the adjacent sub channels with different STA for 20Mhz, 40Mhz the bit is still 0. Can someone help me understand whether NS 700S provides support for the preamble puncture ?
Thanks
- BH_CNETGEAR Expert
Hi,
RS700 currently does not support the preamble puncturing (Multi-RU) function. We've been working on it and aim to release the firmware soon, but I cannot share the schedule. If you are interested in testing some trial builds, I can arrange to send you internal releases. Thanks.
Sorry, I have to correct my response. Regarding the preamble puncturing (Multi-RU) function, we are not certain if we will support it on RS700.
- Caden_CotardAspirant
Thanks for the quick update regarding that. Are there any Netgear WiFi7 AP models that supports preamble puncturing feature and i have WAX-630 Nergear 6GHz access point will that support the puncturing in AX level?
