AcftDriver
Jul 13, 2026Aspirant
Pulsing red light on router
my netgear 12 router has a pulsing red light. the light icon is a circle above a line above two circles. I have power cycled both the router and the modem, same situation. I have accomplished a ro...
Jul 13, 2026Guru - Experienced User
AcftDriver wrote:my netgear 12 router
Do you mean the AX12 (RAX120)?
If you do, can you look at section 1 in the manual, and let us know more precisely where you are seeing this?
- https://www.downloads.netgear.com/files/GDC/RAX120/RAX120_UM_EN.pdf
