AcftDriver
Jul 13, 2026Aspirant
Pulsing red light on router
my netgear 12 router has a pulsing red light. the light icon is a circle above a line above two circles. I have power cycled both the router and the modem, same situation. I have accomplished a ro...
AcftDriver
Jul 14, 2026Aspirant
Morning,
I need to download the manual for my router, but, i have included a picture of the light. since i can only send one picture i will type the info here:
Nighthawk, BE3600 Wifi 7, Model RS100. S/N: 7R315258A018C
John
Jul 14, 2026Guru - Experienced User
AcftDriver wrote:I need to download the manual for my router
It is here:
AcftDriver wrote:i have included a picture of the light.
Although it looks red, it is actually amber. (Not unusual, lots of Netgear's amber LEDs appear red to me in some lighting conditions).
The 4 ethernet LAN ports on the back or your router support gigabit ethernet. The amber color means that at least one of these LAN ports has negotiated a slower speed (usually 100 mbps, but it could even be 10 mbps). It is pulsing because there is traffic going to/from the ethernet-connected devices.
This is not necessarily an error - there are plenty of wired devices out there that use fast ethernet instead of gigabit. Printers, IoT devices, TVs etc.
But it could also be a faulty or old ethernet cable or a bad connector on the router. If you can give us more info on what you have connected to the LAN ports, we could help you figure that out.
- AcftDriverJul 14, 2026Aspirant
Howdy,
Thanks for the link to the manual. very thoughtful for sure. In response to your questions, I have only 3 devices using the LAN ports. My PC, my laptop (using a ethernet to USB adapter, and a QNAP NAS. with that little bit of dangerous knowledge, I started to unplug each one and apparently the NAS is causing the issue. The light turned white after i unplugged the NAS. I'm going to contact them for troubleshooting tips since the router is functioning perfectly. Thanks to everyone responding just proving customer support is fantastic at Netgear!
have a good day
John
- StephenBJul 14, 2026Guru - Experienced User
Definitely the problem then.
While waiting on QNAP, try:
- Connecting the QNAP to a different LAN port on the router. If that is also amber, it rules out a bad LAN port in the router.
- Using the PC or Laptop ethernet cables with the NAS. If that resolves it, the problem is the cable.
If neither help, then look for a second NIC on the back of the QNAP. (Many NAS, including some QNAP models have more than one). If you have another one, try switching to it.
