Smokeyybear0093
Sep 20, 2026Aspirant
QoS:off right under the number of connected devices but I cannot find any setting to enable it
How is this an answer? And how does this mark the inquiry as solved ?!?!
on my router after logging in on the web via the ip/routerlogin.net
it shows QoS:off right under the number of ...
Sep 21, 2026Guru - Experienced User
What router model are you referring too?
Firmware version on the router?
Have you looked on the routers web page under Advanced tab for QoS settings?
