Smokeyybear0093
Sep 20, 2026Aspirant
QoS:off right under the number of connected devices but I cannot find any setting to enable it
How is this an answer? And how does this mark the inquiry as solved ?!?!
on my router after logging in on the web via the ip/routerlogin.net
it shows QoS:off right under the number of ...
Smokeyybear0093
Sep 22, 2026Aspirant
Yes it’s NETGEAR it was through the nighthawk app I believe and I have responded but they’re support must be really backed up because
you can never get a live chat and they take a while to respond Via email.
- StephenBSep 22, 2026Guru - Experienced User
Smokeyybear0093 wrote:
I have responded
Great. Follow up here, so we know how this turns out.
