Smokeyybear0093
Sep 20, 2026Aspirant
QoS:off right under the number of connected devices but I cannot find any setting to enable it
How is this an answer? And how does this mark the inquiry as solved ?!?!
on my router after logging in on the web via the ip/routerlogin.net
it shows QoS:off right under the number of ...
Smokeyybear0093
Sep 22, 2026Aspirant
Yes it’s NETGEAR it was through the nighthawk app I believe and I have responded but they’re support must be really backed up because
you can never get a live chat and they take a while to respond Via email.
schumaku
Sep 22, 2026Guru - Experienced User
Ack. It was like that .. a long time ago.
Some KB fragments still exist, explicitly mentioning a few elderly WiF 5 routers only:
or here
https://kb.netgear.com/25598/How-do-I-configure-the-Dynamic-QoS-feature-on-my-Nighthawk-router
and eg here
https://kb.netgear.com/25614/How-do-I-enable-or-disable-the-Automatic-Dynamic-QoS-database-update-on-my-Nighthawk-X4-R7500
Worth mentioning? On fast Internet connections (so from half a Gigabit and up), the overhead does eat up the advantages. Therefore, I _guess_ modernized automatic QoS is likely disabled.
Please don't blame the messenger for the lack of continuity and documentation on these mostly not inexpenssive consumer routers.
