Smokeyybear0093
Sep 20, 2026Aspirant
QoS:off right under the number of connected devices but I cannot find any setting to enable it
How is this an answer? And how does this mark the inquiry as solved ?!?!
on my router after logging in on the web via the ip/routerlogin.net
it shows QoS:off right under the number of ...
Smokeyybear0093
Sep 21, 2026Aspirant
Why would it show it as off if it was controllable and why would NETGEAR support email me telling me it should be under the advance tab , I’m just trying to figure it out
schumaku
Sep 23, 2026Guru - Experienced User
One essential key function for QoS is the need to run a speed test, and store the results (upstream and downstream) speed.
