SGAguy
Sep 17, 2025Tutor
R6700 to RS600
I have a R6700 - Nighthawk AC1750 Smart WiFi Dual Band Gigabit Router and wanting to know if I upgrade to the RS600 can I forward the configurations over? I have around 100 devices on my R6700 and re...
Sep 17, 2025Guru - Experienced User
You'll need to setup any configurations on the new router. Can't apply a backup from older models to newer models.
Take screen captures from old router so you have visuals.
