Dobester95
Jun 21, 2026Follower
DHCP Issues
I have the exact same issue. I fear the reboot of the RS700. It’s supposed to be their flagship router, but the long reboot time and assigning of IPs is pushing me away from this router.
Jun 22, 2026Guru - Experienced User
Please give details of the issues your seeing with the router?
What is happening if you reboot the router?
What devices do you have connected to the router?
How many devices are connected to the router?
Using default IP address on the router? 192.168.1.1?
IPv6 enabled or disabled on the router?
SPC or Armor enabled on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
