Inmynext40years
Jun 27, 2026Aspirant
Difference between RS140 and RS150
Looking at buying my own router instead of renting one from Spectrum. I have a small place. Main floor is 1100 square feet. I’m wondering what the difference is between the Rs140 and RS150.
Jun 27, 2026Guru - Experienced User
Inmynext40years wrote:I’m wondering what the difference is between the Rs140 and RS150.
No difference on the data sheet. I think the only real difference is that Netgear sells them through different distribution channels. The RS140 is available at Walmart and Amazon, the RS150 is available in more stores (Amazon, Best Buy, Target, Micro Center, Office Depot).
Both should work well for you, so maybe get whatever is cheapest.
- Inmynext40yearsJun 27, 2026Aspirant
Thank you for your response. I couldn’t find a difference between the two either. The RS140 is $40 cheaper though.
