Champnet
Aug 13, 2026Guide
Email logs
New poster so bear with me. Just upgraded from an old D6400 to a brand new RS300. On the D6400 I could regularly email logs but on the RS300 I can't find the option. All on-line advise says the opti...
Champnet
Aug 19, 2026Guide
Finally a comment from Netgear Support "I would recommend performing a factory reset on the RS300"
As the RS300 seems to offer no improvment over the D6400 I might just return the new box as being a waste of time and money. In the meantime I'll ask about the Region security block............
Aug 19, 2026Guru - Experienced User
Ya, FR is not going to fix this. This is a regional security issue that NG has to follow from what I'm told.
If the RS won't work for you needs, then ya, find something else that does. Old stuff I presume won't have this limitation and new stuff may see this issue.
Good Luck.
Champnet wrote:Finally a comment from Netgear Support "I would recommend performing a factory reset on the RS300"
