kindhill457
Jul 15, 2026Follower
Is it better to power down when away/not in use for some time?
If planning to be away and not using WiFi for several days or more, is it a good idea to turn off the Nighthawk router?
Jul 16, 2026Guru - Experienced User
kindhill457 wrote:If planning to be away and not using WiFi for several days or more, is it a good idea to turn off the Nighthawk router?
Personally I don't. I have several things still running that use internet. My HVAC can be controlled remotely, my security system, etc.
It uses 2-4 kwh per week (depending on the model), so the power savings would be small.
