Smokeyybear0093
Sep 20, 2026Aspirant
QoS:off right under the number of connected devices but I cannot find any setting to enable it
How is this an answer? And how does this mark the inquiry as solved ?!?!
on my router after logging in on the web via the ip/routerlogin.net
it shows QoS:off right under the number of ...
Smokeyybear0093
Sep 21, 2026Aspirant
BE5000 (RS150v2)
firmware V 1.2.7.2
I have logged in under the wed interface and cannot find any QoS setting anywhere
Sep 21, 2026Guru - Experienced User
Smokeyybear0093 wrote:I have logged in under the web interface and cannot find any QoS setting anywhere
It's not mentioned in the manual either.
- https://www.downloads.netgear.com/files/GDC/RS150v2/RS150v2-140-130_UM_EN.pdf
