Smokeyybear0093
Sep 20, 2026Aspirant
QoS:off right under the number of connected devices but I cannot find any setting to enable it
How is this an answer? And how does this mark the inquiry as solved ?!?!
on my router after logging in on the web via the ip/routerlogin.net
it shows QoS:off right under the number of ...
Smokeyybear0093
Sep 21, 2026Aspirant
BE5000 (RS150v2)
firmware V 1.2.7.2
I have logged in under the wed interface and cannot find any QoS setting anywhere
schumaku
Sep 21, 2026Guru - Experienced User
Where is the idea that ans RS1nn, RS2nn, RS3nn, RS4nn, RS5nn, RS6nn, or RS7nn router is supposed having any kind of user-controlable QoS settings or controls?
Yes, I see some references to QoS enhancements in some recent firmware release notes.
Beyond, there is no reference to QoS as far as I can see - being in the data sheets, or in the user manuals.
- Smokeyybear0093Sep 21, 2026Aspirant
Why would it show it as off if it was controllable and why would NETGEAR support email me telling me it should be under the advance tab , I’m just trying to figure it out
- schumakuSep 23, 2026Guru - Experienced User
One essential key function for QoS is the need to run a speed test, and store the results (upstream and downstream) speed.
