Smokeyybear0093
Sep 20, 2026Aspirant
QoS:off right under the number of connected devices but I cannot find any setting to enable it
How is this an answer? And how does this mark the inquiry as solved ?!?!
on my router after logging in on the web via the ip/routerlogin.net
it shows QoS:off right under the number of ...
Sep 22, 2026Guru - Experienced User
Smokeyybear0093 wrote:None of this is available on the web interface
Are you certain you contacted Netgear? Your screenshot looks like something AI generated.
Step 2 is oddly worded. AFAIK, no Netgear router provides Gateway->Behavior Navigation.
If you did contact Netgear (not a scam support site), then you should get back to them.
schumaku
StephenB wrote:Your screenshot looks like something AI generated.
Can't agree more.
Looks like the real NTGR support quality of September 2026.
Appears Netgear paid support is using AI, and has not much clue on the products they are supposed do be trained on...
