Riley77
Jun 12, 2026Aspirant
RS280S: Problems with Serviio & Roku Media Player.
Both Items in subject work fine in my old router R6900, but not with the RS280S. I can get a WIFI and hardwired signal to the destination (blueray player), but cannot stream anything. The Serviio sta...
schumaku
Jun 29, 2026Guru - Experienced User
StephenB wrote:As you point out, the feature should only be enabled on networks that you trust, ...
Yes, this is what Microsoft says on the related control panel I had borrowed the text from (to overcome the still broken SaaS platfrom...). As I quoted the original Microsoft Media Streaming Options before:
schumaku wrote:Control Panel -> Network and Internet -> Network and Sharing Centre -> Media streaming options where you can choose Media Streaming Options for Computers and Devices
Media streaming is not turned on
Media streaming allows you to send your music, pictures and videos to other computers and devices on your network. It also allows you to receive media from other computers and devices.
If you turn on media streaming, your current network profile and firewall settings will be modified. You should turn on media streaming only on networks that you trust, such as home or work networks.
[>> Turn on media streaming]
Alone from changing the network location from Private to Public, no changes will be applied unasked - so the Media Streaming wont magically remain available, the service and firewall rules related will be disabled as intended.
schumaku wrote:Alone from changing the network location from Private to Public, no changes will be applied unasked - so the Media Streaming wont magically remain available, the service and firewall rules related will be disabled as intended.
Riley77 says this was working before with the old router. While is isn't clear that "this" included media streaming from the PC, that is definitely one possiblity. So let's assume that is what was meant.
If the PC was using the private profile with media streaming enabled with old network, then the PC would still have media streaming enabled if the PC was still using the private profile.
But if the PC is now using the public profile, then media streaming would be disabled (assuming Riley77 was using private before). In that scenario, the correct fix is to change the profile for the new network to private - NOT to enable media streaming in the public profile.
So it makes sense to check the profile. No idea where you are trying to take this, or argue against that simple check. It is easy to do, and the home network should be set up to use the private profile anyway.
On the other hand, if he didn't actually mean to include media streaming, then it would be best to leave media streaming disabled.
