IllLustration
Sep 23, 2024Follower
Re: RS700 - Disable 5Ghz and 2.4Ghz band
I look forward to (the return of) control over individual bands. I can confirm that the schedule is a workaround for now albeit that it only allows you to turn off a band for a minimum of 30 minutes. In my case, I wish to disable 2.4 GHz only; I have no station that requires it, and I have a lot of Bluetooth and cordless audio about so want to minimise interference. For now just use a different SSID, hide the name in the beacon, and set the channel width to as narrow as possible.
1 Reply
Is Smart Connect enabled on the router?
