jerm1777
May 26, 2026Aspirant
RS700 DHCP Issues with newest firmware
I purchased an RS700 back in February and on the previous firmware I had the slow Wi-Fi issue and once I would login to the web UI and re-apply the Wi-Fi settings it fixed everything and seemed to be...
jerm1777
May 27, 2026Aspirant
The default 192.168.1.1 address string does not work either even without any reservations setup. I mentioned that in the last line of the post you replied to. It does the same thing. I had it setup like that most of the day Monday over several reboots and every time I had to mess with it for an hour to get things to connect again by reapplying Wi-Fi settings. After it did the same thing with that subnet I decided to pop in my 10.31.5.1 subnet since I ruled that out being the issue. I have used the 10.31.5.1 address string for around 15 years in all of my past routers including my old Netgear R7000. The numbers signify something and that is how I came up with it years ago.
I never had a problem setting up reservations inside the pool range, but I always kept them higher up in the range. I can try setting them outside the range and making my pool smaller. I just don't think that will fix the problem either since it does it with the default pool with no reservations set to begin with.
I would contact support and open a ticket, but I am past the 90 days of free support.
May 27, 2026Guru - Experienced User
And I presume you have your prior router that still works with that configuration?
Possible that your RS router maybe faulty.
Can try a 30-30-30 reset and see if this clears the issue or not. First try 192.168.1.1. If not, router would need to be checked by NG.
I'll try your configuration on my RS700.
- jerm1777May 27, 2026Aspirant
I do not have my prior router as I just sold it a few weeks ago. It was an Amplifi Alien and it worked flawlessly with that same configuration.
I can try a 30-30-30 reset and setup again when I get a chance. Oddly enough though this issue didn't happen until I updated to the newest firmware. I did have the slow Wi-Fi speeds on the previous firmware which I had to go into Wi-Fi setup after a reboot and apply the Wi-Fi settings to get the speeds back. Monday I also tried manually reloading the previous firmware and after rebooting I ran into the same DHCP issue so not sure it is firmware related. Until I updated to the newest firmware I had a pretty long uptime of probably at least a month and a half so something could have maybe failed in the router and a reboot triggered it. It's just odd that after messing with settings for a while I can get it stabilized and it's solid until the router is rebooted.
- FURRYe38May 27, 2026Guru - Experienced User
You can try going back to prior FW version and let us know results...
So after work today I did a bit more troubleshooting. The first thing I tried that I didn't do before was disable dynamic DNS. Rebooted router. Same issue. My phone showed IP Configuration failed after trying to connect to Wi-Fi multiple times. After about 20 minutes my desktop computer finally connected so I logged in to the web UI and looked at attached devices. Many of them had 169.x.x.x IPs or 0.0.0.0 like before. Then I went to Wi-Fi setup and didn't make any changes, but just clicked apply to re-apply my Wi-Fi settings. Then after about 2 minutes all of my devices connected again.
Next step was to set the DHCP pool back to 192.168.1.1 and removed all IP reservations. Rebooted router. Same as above after the reboot.
Third step was to load the prior firmware again. I tried this before as stated above, but figured I would try it again. Loaded the firmware manually from Edge browser. After a reboot same issue. So I reloaded the newest firmware again and rebooted.
So 4 times I had to go through the steps listed in my first paragraph to get things stable again.
I use smart connect in my Wi-Fi settings. I am wondering if maybe this could be related? If it's a feature it shouldn't cause any issue I would think, but with 60ish devices maybe something is causing it to hang up on router bootup? I also have a 2.4Ghz IoT network setup as well.
Wondering if your unit maybe faulty.
- CrimpOnMay 27, 2026Guru - Experienced User
When faced with DHCP issues, I typically open Wireshark (free for Windows from https://www.wireshark.org) to monitor the network interface (in this case the WiFi adapter) and set it to display DHCP packets only. (type dhcp in the bar at the top). Then, restart the RS700.
What one would expect to happen is...
- When the router reboots, the PC should reconnect automatically to WiFi.
- The PC should issue a DHCP request.
- The RS700 should respond with a DHCP offer.
I think I may have found the solution. I don't know why I didn't try this before, but I disabled smart connect under wireless setup. I left all of my SSID names the same for 2.4, 5, and 6Ghz. I rebooted the router and within 5 minutes it was fully back online and all devices connected.
I kept that enabled because it is supposed to be a useful feature, but apparently it must be buggy to cause the same exact issue on repeated reboots of the router.
I am going to try rebooting a few more times this evening and make sure it is still coming back online within a few minutes with all devices connected.
OK, I applied your subnet configuration to my RS700.
Thought default DHCP IP address pool range is set for .100 to .150 for my needs here.
Smart Connect enabled on my router.
Got a few devices connected and there not exhibiting any issues:
Did a couple of reboots on the router.
Router came back to ready in about 2-3 minutes.
I noticed one reboot, two devices had same IP address. I rebooted them.
Rebooted the router a 2nd time. All devices reconnected in good time with out issues.
Will let this run for a day or two.
Not sure if you saw my reply to CrimpOn above, but I think I fixed the issue:
- jerm1777May 28, 2026Aspirant
I think I spoke too soon. I did a few reboots last night with smart connect off and it still takes the router around 20-30 mins until it stabilizes and everything connects. With smart connect off I don't have to go into wireless setup and apply the settings each time the router is rebooted though. I just have to wait until things stabilize on their own. I logged in to the web UI last night after a reboot and this is what I saw in connected devices. Still some 169.x.x.x invalid IPs and 0.0.0.0 and I noticed the Device Name and Device Models in the list are switched around between devices. You can see my LIFX bulbs are showing the device name as Rokus and my Nest Mini and Chromecast are showing device name as LIFX bulbs. These are just examples though as there are much more than that. After about 30 minutes everything seems to stabilize and fix itself. This is definitely some weird behavior though.
- FURRYe38May 28, 2026Guru - Experienced User
Wondering if the total amount of connected devices is causing issues.
Any way you can maybe turn OFF some of these devices and see if the router continue to have issues? Possible router is having issues handling this many devices.
My router came to ready in 2-3 minutes however only have about 5 devices connected to it currently.
I could attempt to do that, but the router advertises that it can support up to 200 devices and I don't even have a third of that amount connecting to it. If my previous two routers could reboot and be up and running within 5 minutes of a reboot I would think this one should be able to handle that as well.
Ok. Well possible there is some problem happening during reboot and the DHCP services mis handling all the devices trying to get connected at once during the reboot process. Something NG will need to review.
Is there a way to get in touch with them about this other than having to pay for support? I wasn't sure if they replied here or not either.
Someone should be reaching out to you via PM.
Awesome thanks! I was going to submit a hardware support request, but I am still not entirely sure if this is an actual hardware issue or if it is software.
Something to do while you wait for NG to contact you, enable debug logs under router IP address/debug.htm...Have the WAN/LAN check box enabled as well. Start logging. Give about 5-10 minutes then save off the logs and post to a cloud share. Send the link to whom contacts you via PM. Hopefully this will be helpful as well.
