jerm1777
May 26, 2026Aspirant
RS700 DHCP Issues with newest firmware
I purchased an RS700 back in February and on the previous firmware I had the slow Wi-Fi issue and once I would login to the web UI and re-apply the Wi-Fi settings it fixed everything and seemed to be...
jerm1777
May 27, 2026Aspirant
So after work today I did a bit more troubleshooting. The first thing I tried that I didn't do before was disable dynamic DNS. Rebooted router. Same issue. My phone showed IP Configuration failed after trying to connect to Wi-Fi multiple times. After about 20 minutes my desktop computer finally connected so I logged in to the web UI and looked at attached devices. Many of them had 169.x.x.x IPs or 0.0.0.0 like before. Then I went to Wi-Fi setup and didn't make any changes, but just clicked apply to re-apply my Wi-Fi settings. Then after about 2 minutes all of my devices connected again.
Next step was to set the DHCP pool back to 192.168.1.1 and removed all IP reservations. Rebooted router. Same as above after the reboot.
Third step was to load the prior firmware again. I tried this before as stated above, but figured I would try it again. Loaded the firmware manually from Edge browser. After a reboot same issue. So I reloaded the newest firmware again and rebooted.
So 4 times I had to go through the steps listed in my first paragraph to get things stable again.
I use smart connect in my Wi-Fi settings. I am wondering if maybe this could be related? If it's a feature it shouldn't cause any issue I would think, but with 60ish devices maybe something is causing it to hang up on router bootup? I also have a 2.4Ghz IoT network setup as well.
CrimpOn
May 27, 2026Guru - Experienced User
When faced with DHCP issues, I typically open Wireshark (free for Windows from https://www.wireshark.org) to monitor the network interface (in this case the WiFi adapter) and set it to display DHCP packets only. (type dhcp in the bar at the top). Then, restart the RS700.
What one would expect to happen is...
- When the router reboots, the PC should reconnect automatically to WiFi.
- The PC should issue a DHCP request.
- The RS700 should respond with a DHCP offer.
- jerm1777May 27, 2026Aspirant
I think I may have found the solution. I don't know why I didn't try this before, but I disabled smart connect under wireless setup. I left all of my SSID names the same for 2.4, 5, and 6Ghz. I rebooted the router and within 5 minutes it was fully back online and all devices connected.
I kept that enabled because it is supposed to be a useful feature, but apparently it must be buggy to cause the same exact issue on repeated reboots of the router.
I am going to try rebooting a few more times this evening and make sure it is still coming back online within a few minutes with all devices connected.
