jerm1777
May 26, 2026Aspirant
RS700 DHCP Issues with newest firmware
I purchased an RS700 back in February and on the previous firmware I had the slow Wi-Fi issue and once I would login to the web UI and re-apply the Wi-Fi settings it fixed everything and seemed to be...
jerm1777
May 28, 2026Aspirant
Is there a way to get in touch with them about this other than having to pay for support? I wasn't sure if they replied here or not either.
May 28, 2026Guru - Experienced User
Someone should be reaching out to you via PM.
- jerm1777May 28, 2026Aspirant
Awesome thanks! I was going to submit a hardware support request, but I am still not entirely sure if this is an actual hardware issue or if it is software.
- FURRYe38May 28, 2026Guru - Experienced User
Something to do while you wait for NG to contact you, enable debug logs under router IP address/debug.htm...Have the WAN/LAN check box enabled as well. Start logging. Give about 5-10 minutes then save off the logs and post to a cloud share. Send the link to whom contacts you via PM. Hopefully this will be helpful as well.
