LaddieParker's avatar
Nov 02, 2025
RS700 IPv4 Lease Not Renewing (still not fixed).
  I have a Nighthawk RS700 currently running firmware 1.0.9.16. There is a problem with renewing the IPv4 lease. If I restart the router it picks up an Ipv4 address with a 24 hour lease. After 12 ho...
  • BH_C's avatar
    BH_C
    Nov 06, 2025
    Hi LaddieParker​ ,
    I'm sorry for the late response. As you mentioned, an earlier post reported an issue with the similar symptom, and it's also an ISP in UK. I worked with Intoxicating, who posted that issue, and had the issue fixed. I just PM you the trial firmware v1.0.9.101_25.7.19 which fixes the issue, please give it a try to see if that fixes the issue you ran into.
    Thanks.
