MrChrisH
Oct 23, 2025Aspirant
RS700 VPN Service certs incomplete?
I've been setting up NoIP and the VPN Service on my RS700. I'm on firmware version V1.0.9.6_2.0.100. After much tinkering and following much of the helpful advice here, I have a connection that ...
MrChrisH
Oct 24, 2025Aspirant
Interesting. I thought the issue was in the generated server cert and it needing the Key Usage defined. Maybe I have issues in two places! Thanks for sharing.
Let's see what Netgear come back with
Oct 27, 2025Guru - Experienced User
FYI, NG reproduced the issue. So all in there hands to get it fixed. Don't know when that will be so will need to be patient and keep an eye on next FW update. Hopefully get fix by then.
