NG7856's avatar
NG7856
Guide
May 30, 2025
Recommended extender for BE17000 — Nighthawk WiFi 7 Tri-Band Router
I have three questions:
  1. I have an old R8000P. I does not have smart connect and I can set a different name and password for each frequency.   Can I do this with the BE17000?
      2.What is a great extender to use with the BE17000?  I would like at less 2 ports?
       3. Is the power supply for the BE17000 100/240  - 60hz/50hz?
  • See more info here regarding Orbi systems: https://community.netgear.com/discussions/en-home-orbi-be/orbi-970---separate-name-per-wifi-freq-/2458153
  • FURRYe38's avatar
  • Thank you for your reply.  I have the EA 80 (AC3000) but since I was updating the router I thought about getting a new extender.  I was thinking about going with ORBI 970 but unlike the T-Link router you cannot disable the smart connect.  I have read "many" articles about how the smart connect is not ready that smart and if you want a different GHZ than what smart connect likes it is impossible to configure.  It looks like old versions of ORBI had the smart connect disable switch - oh well!
    Thanks
  • FURRYe38's avatar
    That model router do you have? RS###?
    NG doesn't have any WiFi 7 extenders available. Last working extender that could help but won't pass WiFi7 would be the EAX series. My EAX80 worked good with my RS600.
