LG2
Sep 14, 2025Aspirant
RS 700. Do I really need a subsciption for it to work?
LG2
Thank You FURRY! I cannot at the moment. But I saved the link you posted into my favorites. Thanks again! Will post here as soon as I can have a go at this!
Sep 14, 2025Guru - Experienced User
Sounds good, when you get time. Also a NG router can be setup manually while offline and disconnected from the ISP modem as well. If you feel the need. Something I do all the time when I'm getting ready to put something else online.
