ddbech3
Sep 18, 2025Aspirant
Rs 700 The WiFi Scheduler function doesnt work at all
The WiFi Scheduler function On rs 700 doesnt work even after scheduling and saving the only scheduler that works is on the 6 ghz please help thank you
Sep 18, 2025Guru - Experienced User
What firmware version are you using?
So setting up the scheduler only effects the 6Ghz wifi radio?
Do you have Smart Connect enabled?
How do you have the scheduler configured?
