ddbech3
Sep 18, 2025Aspirant
Rs 700 The WiFi Scheduler function doesnt work at all
The WiFi Scheduler function On rs 700 doesnt work even after scheduling and saving the only scheduler that works is on the 6 ghz please help thank you
ddbech3
Smart connection not enabled
schedule configured from 3:00pm to 3:30pm
Sep 18, 2025Guru - Experienced User
What is the actual version #?
Does this happen if you enable Smart Connect?
ddbech3 wrote:Smart connection not enabled
- ddbech3Sep 18, 2025Aspirant
firmware version v1.0.7.96
Sorry the schedule is fro 3:30 pm to 3:00pm
- FURRYe38Sep 18, 2025Guru - Experienced User
Ok, checking my RS600 with Smart Connect enabled, I set up similar schedule and have a wifi scanner running on a Android pad and just noticed both 2.4 and 5Ghz signals are not longer present.
Going to check with SC disabled and see what happens...
