ddbech3
Sep 18, 2025Aspirant
Rs 700 The WiFi Scheduler function doesnt work at all
The WiFi Scheduler function On rs 700 doesnt work even after scheduling and saving the only scheduler that works is on the 6 ghz please help thank you
CrimpOn
Sep 18, 2025Guru - Experienced User
Sad. No help from Netgear without paying $99/year.
Can you make that screen capture?
ddbech3
Don't know how to explain it but the schedule seem to be working
thank you for your time to reply
- FURRYe38Sep 18, 2025Guru - Experienced User
Is Smart Connect enabled or disabled while schedule seems to be working now?
