ddbech3
Sep 18, 2025Aspirant
Rs 700 The WiFi Scheduler function doesnt work at all
The WiFi Scheduler function On rs 700 doesnt work even after scheduling and saving the only scheduler that works is on the 6 ghz please help thank you
Sep 18, 2025Guru - Experienced User
Something to be aware of, if Smart Connect is enabled, there will be one wifi schedule for all bands that should shut OFF all radios when SC is enabled.
If SC is not enabled, there will be 3 separate wifi schedule configurations for each radio that you would need to configure. Something I found with my RS600.
Good Luck.
