Jeffro535
Jul 19, 2025Tutor
RS 700 will not allow some devices to connect to internet after last firmware update
Updated my RS 700 to 1.0.9.6 and now it takes 2 or 3 reboots for it to sync with the modem and when it does, it will not allow 2 of my devices on the 2.4ghz network to connect to the internet. I’ve r...
- Aug 05, 2025
So I wound up rolling the firmware back to the previous version and everything started working again. It seems NETGEAR is working the solution and has some trial firmware available
CrimpOn
Jul 19, 2025Guru - Experienced User
What are these two devices?
What security level is set on the 2.4G WiFi?
(see page 73 of the User Manual https://www.downloads.netgear.com/files/GDC/RS700S/RS700_UM_EN.pdf)
Jeffro535
Jul 19, 2025Tutor
The two are a Rachio sprinkler controller and a Ring Chime…all the other Ring devices work fine security is set to wpa 2&3 personal. Everything was working fine until the firmware update
