Jeffro535
Jul 19, 2025Tutor
RS 700 will not allow some devices to connect to internet after last firmware update
Updated my RS 700 to 1.0.9.6 and now it takes 2 or 3 reboots for it to sync with the modem and when it does, it will not allow 2 of my devices on the 2.4ghz network to connect to the internet. I’ve r...
- Aug 05, 2025
So I wound up rolling the firmware back to the previous version and everything started working again. It seems NETGEAR is working the solution and has some trial firmware available
SsnickersS
Aug 14, 2025Apprentice
Hello,
I had the same with this last firmware (some devices won't connect).
I have also noticed that the list of the connected devices is completly false: some devices connected using ethernet will appear connected with wifi 6Ghz! Or connected wit 2,4 Ghz will appears connected with 5 Ghz? this bug is not so important but it was ok before.
There was something go: when testing the connection (speedtest) the result was ok and confim that I have 8 GB/8GB, with the previous firware it was less.
Now, I'm back with the previous firmware and it's ok.
Thank you
