vinoureux's avatar
vinoureux
Follower
May 20, 2025
RS100 wifi schedule
Upgrading from an old Netgear router I would like to setup a WIFI schedule.
WIth the old router it was straight forward to set times during which the Wifi was simply shut off. With the RS100 I do not find/see the option.
Any idea where to find this? I sure hope it did not get removed, it being a neat feature...
1 Reply
  • FURRYe38's avatar
    If it's not seen anywhere in the User Manual or in the routers web page, then that feature may not be available.
