Jimmyinaus
Jun 12, 2025Aspirant
RS200 coverage area
Hi all, New here to the group. Purchased a RS200 today, box says coverage area being 185sqm2 but the website says it's 230sqm2. Is that an error on the website then or false advertising? Tha...
michaelkenward
Jun 12, 2025Guru - Experienced User
Numbers like those are always guesstimates. WiFi coverage depends on so many variables. The building material. How many rooms. The layout. The connecting devices. And more.
I would take both of those statements with a pinch of salt.
The Technical Specifications for the RS200 claim "Router provides up to 2,500 sq. ft". That's a bit more than 230 sq. m.
Does it do what you want?
Just another user with time on their hands.
Jimmyinaus
Hi Michael,
I haven't set it up yet. Was wondering to check before I open it or exchange it to RS300 :)
- FURRYe38Jun 12, 2025Guru - Experienced User
From the spec sheets, both 200 and 300 seem to have around same coverage ranges:
https://www.downloads.netgear.com/files/GDC/RS200/RS200_TS.pdf
https://www.downloads.netgear.com/files/GDC/RS300/RS300_TS.pdf
