Grumblebow
Sep 22, 2025Aspirant
RS200 doesn't recognize Ethernet cable
Replaced router because of an EOS notice, but it refuses to recognize the Ethernet cable from the router. I can get internet access through the old router on that port, so it doesn't appear to be a h...
CrimpOn
Sep 22, 2025Guru - Experienced User
It would be useful to know what device the RS200 router WAN port is connected to.
- GrumblebowSep 22, 2025Aspirant
To the modem.
- StephenBSep 23, 2025Guru - Experienced User
Grumblebow: The question is exactly what modem (model and manufacturer).
It would also be useful to know if the modem's ethernet port supports 2.5 gbps or not.
Have you tried a different ethernet cable?
