Grumblebow
Sep 22, 2025Aspirant
RS200 doesn't recognize Ethernet cable
Replaced router because of an EOS notice, but it refuses to recognize the Ethernet cable from the router. I can get internet access through the old router on that port, so it doesn't appear to be a h...
Sep 23, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
