Grumblebow
Sep 22, 2025Aspirant
RS200 doesn't recognize Ethernet cable
Replaced router because of an EOS notice, but it refuses to recognize the Ethernet cable from the router. I can get internet access through the old router on that port, so it doesn't appear to be a h...
Grumblebow
Sep 23, 2025Aspirant
Update: it works fine if I run the cable from the modem through a switch and then another cable to the RS200 (they're all CAT5 and worked fine with the old router). It's not ideal but it works.
- FURRYe38Sep 23, 2025Guru - Experienced User
Seems like some interoperability issue between the RS router and your modem or ONT you have.
- StephenBSep 23, 2025Guru - Experienced User
That's good, but I suggest replacing that setup with a cat-6a patch cable. They are quite inexpensive.
There are several possible reasons why CAT5 might not work well (particularly if they are ordinary CAT5 and not CAT5E). You might want to run a speed test, and see if you are getting the full internet speed you are paying for.
