Riley77
Jun 12, 2026Aspirant
RS280S: Problems with Serviio & Roku Media Player.
Both Items in subject work fine in my old router R6900, but not with the RS280S. I can get a WIFI and hardwired signal to the destination (blueray player), but cannot stream anything. The Serviio sta...
Riley77
Jun 28, 2026Aspirant
Thanks for all the replies!
Now I sort of have it working. I assigned a static IP in the router for the bluray player. After rebooting the PC, it works fine for about 30 minutes, then drops the broadcast.
The Roku media player and the default Windows media server only work when the Serviio works. I ran the old R6900 with no special settings and everything was fine.
Any more suggestions or any above I missed and should try?
- StephenBJun 28, 2026Guru - Experienced User
Did you set up the Windows Media Player as a server?
If you did, have you also checked that the PC has classified the network as private?
- schumakuJun 28, 2026Guru - Experienced User
The legancy Media Player Its not a server - it can "just" play local stored media.
Windows 11 is offering a Media streaming feature, acting as a DLNA server -if- enabled.
Control Panel -> Network and Internet -> Network and Sharing Centre -> Media streaming options where you can choose Media Streaming Options for Computers and Devices
Media streaming is not turned on
Media streaming allows you to send your music, pictures and videos to other computers and devices on your network. It also allows you to receive media from other computers and devices.
If you turn on media streaming, your current network profile and firewall settings will be modified. You should turn on media streaming only on networks that you trust, such as home or work networks.
[>> Turn on media streaming]
Alas, for once this appears to have no impact - the media streaming option applies to the current network profile in my reading and understanding.
The legacy Windows Media player can list and play local files as well as multiple DLNA Servers available on the network.
Of course, both of these two DLNA services can be configured pointing to different, dedicated media folders - which don't have to be the same.
By default, the Media streaming service does work (unless configured differently) in the Windows default media folders for Pictures, Music, Videos. If there are no media stored under these folders there isn't a lot of media visible there. This cloud explain why you have to run the Serviio server to see DLNA media.
As you point out, the feature should only be enabled on networks that you trust, such as home or work networks. Which means it should only be enabled in the private network profile.
Since this was working with the old router, I am thinking that old wifi network might have been classified as private on the PC - but that the new network might be classified as public - where it might not (and should not) be enabled. Note I did test this - enabling the media streaming option on my home wifi network. It was disabled when I switched to a different network (classified as public), but then immediately became enabled when I changed that network from public to private.
The other possibility I was wondering about is that perhaps Riley77 meant to say default Windows media player (and that media streaming is not enabled on the PC). In which case, you'd expect it to only find the media when the Serviio server is running.
- schumakuJun 29, 2026Guru - Experienced User
The Roku media player and the default Windows media server only work when the Serviio works.As mentioned before, there are -three- components playing together in a active working (or here working for just 30 minutes) DLNA environment.
Which device are you using as the DMC, the Digtal Media Controller?
- The Roku Media Player with it's remote (so making it DMC and DMR) for playback on your TV?
- Or the unknonwn Bluray player where you are using it's remote (so again making it DMC and DMR) for playback on your TV?
- Or anouther DLNA App on a mobile or an application like the Microsoft Media Player?
- Or the Serviio Console as used for managing your media server settings, or the Serviio MediaBrowser (now known as Web Player) for controlling the content playback in a browser?
Even with the DMS and the DMR active, loosing the DMC session (or connection), can stop the playback.
The DMS (the server part) seems to be typically your Serviio PC from what I understand. I'm confused to see another device (like a bluray player) in the equation, along with the the Roku Media Player...
