loadii's avatar
loadii
rs300 - guest and iot
just got a rs300.  it is in AP mode.  the main network works fine.  created a guest network on wifi 5g using wpa2 and wpa3.  the ssid randomly shows up and when it does clients can’t join.  also created an iot network using 2.4g only.  the ssid shows up and can connect to it however devices on iot network cant access internet or ping the local ips.  using firmware 1.0.6.16.
any suggestions?
  • updating to the latest firmware fixed the issue.  thank you.
