loadii
Jun 07, 2026Aspirant
rs300 - guest and iot
just got a rs300. it is in AP mode. the main network works fine. created a guest network on wifi 5g using wpa2 and wpa3. the ssid randomly shows up and when it does clients can’t join. also created an iot network using 2.4g only. the ssid shows up and can connect to it however devices on iot network cant access internet or ping the local ips. using firmware 1.0.6.16.
any suggestions?
updating to the latest firmware fixed the issue. thank you.
- loadiiAspirant
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- loadiiAspirant
should this be updated manually? I use the app and it says I am on the latest firmware already.
Yes. Manually update. v1.0.6.16 is not latest version.
