hexcei
Jul 11, 2024Guide
RS300 Region Incorrect
Hi,
Just a quick question. I live in the continental US (WI). The region in the UI of the RS300 says CANADA and is greyed out and cannot be changed. When I got the router first thing was a manual FW upgrade to 1.0.0.38, factory reset using the reset button in the back, and set it up all manually.
Everything works fine. but is this a problem, are the radios (power,channels,etc) all the same CAN vs US, don't really want to return it. Curious if anyone else ran into this. This was ordered direct from netgear.com.
Thanks, - Brian
- OK, if you purchased it from NETGEAR.com then I don't need to see the giftbox. - So that should be a mistake on the shipment, you can contact our customer support (1-866-534-9377) to replace it with a new one. If you run into problems with the support, please send me your case number through private message and I will look into it. - I'm sorry about the mistake.
- FURRYe38Guru - Experienced UserSomething to contact NG support about.
- BH_CNETGEAR ExpertHi Brian, The only difference between Canada region and US region is the WiFi transmitting power for US is a bit higher than Canada for some 5GHz channels because of different regulation requirements between US/FCC and Canada/IC. Where did you purchase the product? can you share a photo of the giftbox of the RS300? Thanks. - hexceiGuideIt was purchased 08July from Netgear.com directly, shipped from Netgear, City of Industry CA, and arrived 10July. I am sorry, by giftbox, did you mean you just wanted a picture of the retail box?. Thanks much. - BH_CNETGEAR ExpertOK, if you purchased it from NETGEAR.com then I don't need to see the giftbox. So that should be a mistake on the shipment, you can contact our customer support (1-866-534-9377) to replace it with a new one. If you run into problems with the support, please send me your case number through private message and I will look into it. I'm sorry about the mistake.
