The-Ark's avatar
The-Ark
Guide
Jul 04, 2024
RS300 Unable to turn of QOS function
I am unable to turn on QOS function
Already try to reset multiple times~ Still unable to turn on the QOS
After speed test~ The QOS fail to activate
1 Reply
  • plemans's avatar
    My understanding (I'm not netgear) is that the QoS settings were removed. They weren't recommended at speeds over 250mbps anyway. If you log into the debug page (routers IP address/debug.htm) there's an option to enable it in the GUI. But it might be buggy or not fully implemented.
