ThorPan
Sep 30, 2025Aspirant
RS500 — Nighthawk BE12000 WiFi 7 Tri-Band Router Protection Engine Problems
Hi,
Unfortunately, I'm 2 weeks past the measly 90 days of support for my RS500 - Nighthawk BE12000 router, so I'm posting here instead, trying to prompt Netgear to actually create firmware that works reliably.
So, the current problem: It keeps dropping connections on both of our new iPhones, Ting sensor, Roomba, a Dell laptop, and an iPad Pro, in addition to most of our SmartHome devices at one time or another. Most of the time, it's an authentication problem, even though I know the password is correct. Unfortunately, several devices don't say the exact cause of the problem. When this happens, it's impossible to reconnect the devices to the WiFi without rebooting the router, and even then, it's still iffy. The 3 Ethernet connections being used don't seem to have a problem. We have fiber cable to the modem, and the connection between that and the router is using the cable that came with the router. Can't blame anything on the connections.
Here's the information regarding my router:
Hardware Version - RS500
Firmware Version - V1.0.5.12
GUI Language Version - V1.0.0.454
Protection Engine Version - 2.2.214.4/1.0.0.2124
Operation Mode - Router
CPU Load - CPU1: 10.89% CPU2: 11.11% CPU3: 9.00% CPU4: 16.16%
Memory Usage (Used/Total) - 633MB/2018MB
Flash Usage (Used/Total) - 430MB/512MB
System Uptime - 04:59:59
LAN Port - MAC Address - xx:xx:xx:xx:xx:xx
IP Address - xxx.xxx.xxx.xxx
DHCP Server - On
IP Subnet Mask - 255.255.255.0
DHCP Lease Time - 24 Hours
I tried turning off the 6 GHz radio, but that didn't help.
Next, I changed Security from WPA2-Personal(AES) + WPA3-Personal to WPA2-Personal(AES) on both the 2.4 GHz and the 5 GHz networks. That didn't help either.
In researching on the Internet, I read that a LOT of people have the exact same problems that I'm having, and the Protection Engine is the most likely culprit. I disabled it, and all of a sudden, everything is working as expected. After the first 24 hours, I re-enabled WPA2-Personal(AES) + WPA3-Personal security on both the 2.4 GHZ and 5 GHz networks. Still no problems. A day later, I re-enabled the 6 GHz network, and everything is still working OK.
Therefore, using a bit of deductive reasoning, I have concluded that the Netgear Protection Engine is not working properly. I do NOT want to leave this feature disabled for security reasons and I paid for it and expect it to work, but we need to have fast, RELIABLE, WiFi available throughout our home at all times. Unfortunately, this Netgear product is NOT providing reliable WiFi connections when the Protection Engine is enabled.
This is just the latest issue. Originally, when I purchased this router, it upgraded itself to firmware v.1.0.1.90. Using the web based interface, I immediately noticed that NO Devices showed up on the Devices page. After spending over 20 hours working with Netgear to find a solution, I tried downgrading to v.1.0.1.74. Netgear did absolutely NOTHING to troubleshoot this problem, and I did it all on my own. They had me try all sorts of BS things even though they could have easily duplicated the problem themselves. I told them what I found regarding the firmware downgrade, but they didn't seem to care. Netgear eventually wanted my configuration file. NOT!!! It contains information regarding our entire network including the router password. They closed the case without a resolution.
So, v.1.0.1.74 is humming along just fine for a while, and then all of a sudden, the WAN uplink speed was only 100 Mbps, confirmed by my Internet provider. Not even close to acceptable!! Turns out that Netgear new about it, and already had a fix via v.1.0.5.12. I installed it, and it appeared to work fine for a while, and then all of a sudden, devices kept disconnecting and wouldn't reconnect. That's the latest issue, as described above.
Can Netgear ever make a firmware version that doesn't have bugs in its basic functionality!?!?! I've never seen such a POS router before in my life!! The hardware may be good, but the firmware totally sucks! In less than 3 months, I've had 3 different firmware versions, and all 3 had a different problem that affected its usefulness. I used to use LinkSys routers, and they always just worked without any issues; ever. Why can't Netgear do the same??
So, does anyone have any useful suggestions other than hoping Netgear creates a new firmware version that accidentally fixes this problem and doesn't create a totally new problem? Maybe a version that actually works this time? Perhaps I should sell this overly priced Netgear paperweight really cheap and use the money to buy a new TP-Link router that actually works as expected!
Thanks!!
- ThorPanAspirant
If I disable the Protection Engine, most of the things in our home disconnect eventually and don't reconnect, so that's not acceptable since we have a SmartHome, and there's a home business also ran from our home that relies on the Internet to be working.
A reset loses all of the Devices I have defined by name, so that's a non-starter for me.
Changing channels will not affect how devices connect to WiFi, so is a waste of time.
- ThorPanAspirant
Hi,
Thanks for your response!
Who is officially recommending the Protection Engine be turned off? It's it's Netgear, then they KNOW there's an issue with their code and should fix it. The Protection Engine doesn't protect anything when it's disabled, and causes security concerns for everyone who has it disabled. My old router was probably more secure than this one is with the Protection Engine disabled. At least there was something there, even if it was outdated!
It's a ZHONE ONT, but it's not the WAN side having the problem; it's the LAN side on WiFi that's having issues. The WAN uplink fix was in firmware v.1.0.5.12, and that's still working OK.
The link between the modem and router was the cable supplied by Netgear, so we can assume it was the appropriate type of cable. There are no markings that I can see on the cable to determine specifications. When I had the WAN problem, I tried a different CAT6 cable, and it still had the problem.
I'm using channel 11 on the 2.4 GHz WiFi, and all the rest are set to Auto to allow the router to choose the best channel to avoid local interference with others in the neighborhood.
None of our devices are using random MAC addresses. Even if they were, they only randomize when they connect to a different WiFi network.
Since setting up the router, I have not done a factory reset on it since it took me hours of work putting Device Names on the 30+ devices connected to the router, and I wasn't about to go through all of that trouble again since my configuration is a bit more complicated than the typical user's is.
IPV6 is disabled since it doesn't perform as well as expected due to the translation to IPV4.
I don't recall what the default IP address pool was, but I set mine to be something of my own choosing.
We've already past this onto NG and are aware of it. All in there hands.
Actually PE is having an oppostie effect, please review:
Protection Engine and Stealth ports | NETGEAR Communities
TCP SYN Flooding on RAX54v2 Router, Please help! | NETGEAR Communities
Which we have also passed on to NG as well for review.
Considering all that, you can keep it enabled if you want too. Will need to be patient while NG works on this. No idea when that will be. I have been using my RS router with it disabled and it's been working fine for me.
Please try manual channels 11 and 40.
When doing a factory reset, it's not necessary to input or reconnect devices or manually connect devices, if you use same SSID name and password as before, then all of your wifi devices will auto reconnect.
Also be sure to save off a backup configuration to file as well. Saves time if a FR is needed.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Currently it's recommended to disable Protection Engine.
Also is IPv6 enabled, if so, disable it as well.
What channels are you using on the RS router? Please try 1 and 40.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR CommunitiesHas a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
