SteelerNights
Jul 30, 2025Guide
RS600 All 2.5 Ghz devices stopped connecting. Rebooting only fix
Brand new RS600. 1 month old. ALL 2.5 GHZ devices (thermostat, printers) lost connection to the router. Though they could see the SSID, they could not connect. Tried resetting the connection on...
- Aug 09, 2025
Good to hear. Probably mark this as solved then. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 31, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How is the wifi configured? Is smart connect enabled or disabled?
What channels are you using?
How many devices in total do you have connected to the router at once?
How are the advanced WiFi settings configured?
- SteelerNightsJul 31, 2025Guide
I was on .90, but working on another issue, development sent me .113 which I installed this morning. The issue happened on .90.
Smart Connect is enabled.
Wpa2+3 is enabled
Channels - all auto
2.5 is set to up to .7 Bbps
Total devices, about 10.
IP Camera, Thermostat, 4 phones, 4 laptops
- FURRYe38Jul 31, 2025Guru - Experienced User
Ok, lets let the beta version run for a bit and monitor.
