SteelerNights
Jul 30, 2025Guide
RS600 All 2.5 Ghz devices stopped connecting. Rebooting only fix
Brand new RS600. 1 month old. ALL 2.5 GHZ devices (thermostat, printers) lost connection to the router. Though they could see the SSID, they could not connect. Tried resetting the connection on...
- Aug 09, 2025
Good to hear. Probably mark this as solved then. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
SteelerNights
Jul 31, 2025Guide
I was on .90, but working on another issue, development sent me .113 which I installed this morning. The issue happened on .90.
Smart Connect is enabled.
Wpa2+3 is enabled
Channels - all auto
2.5 is set to up to .7 Bbps
Total devices, about 10.
IP Camera, Thermostat, 4 phones, 4 laptops
Jul 31, 2025Guru - Experienced User
Ok, lets let the beta version run for a bit and monitor.
