SteelerNights
Jul 30, 2025Guide
RS600 All 2.5 Ghz devices stopped connecting. Rebooting only fix
Brand new RS600. 1 month old. ALL 2.5 GHZ devices (thermostat, printers) lost connection to the router. Though they could see the SSID, they could not connect. Tried resetting the connection on...
- Aug 09, 2025
Good to hear. Probably mark this as solved then. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Aug 07, 2025Guru - Experienced User
FYI, new FW available:
NOTICE: New - RS200v1/RS500/RS600 Firmware Version 1.0.5.12 Released | NETGEAR Communities
SteelerNights
Aug 09, 2025Guide
Thank you, how does this relate to
Router Firmware Version V1.0.5.113
1.0.5.113 (beta) seems to be much higher (newer?) than 1.0.5.12...
- FURRYe38Aug 09, 2025Guru - Experienced User
Last you reported being on older released FW and had not reported anything later then that. NG just released v.12 which is current released version and was posted here to let you know since we didn't get any feedback from you about a beta. If you have a beta loaded, then keep what is working for you.
- SteelerNightsAug 09, 2025Guide
Busy time at work, sorry. Beta seems to have solved the problem with the NAT issue. I'll monitor the issues with 2.4 ghz. Problem with 2.4 has not returned on the beta so far.
Thanks for your work.
Enjoy. 📡
