SteelerNights's avatar
Jul 30, 2025
RS600 All 2.5 Ghz devices stopped connecting. Rebooting only fix
Brand new RS600.  1 month old.  ALL 2.5 GHZ devices (thermostat, printers) lost connection to the router. Though they could see the SSID, they could not connect.   Tried resetting the connection on...
  • FURRYe38's avatar
    Good to hear. Probably mark this as solved then. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
    Enjoy. 📡
